Ana içeriğe geç
Huawei P8 Front Camera Replacement
Neye ihtiyacın var
  1. Huawei P8 Front Camera Replacement, Huawei P8 Battery Replacement: adım 1, 2 resimden 1. Huawei P8 Front Camera Replacement, Huawei P8 Battery Replacement: adım 1, 2 resimden 2.
    • First switch off your phone.
    • Remove the trays for the SD card and the SIM card.
    FixBot'a Sor
  2. Huawei P8 Front Camera Replacement: adım 2, 3 resimden 1. Huawei P8 Front Camera Replacement: adım 2, 3 resimden 2. Huawei P8 Front Camera Replacement: adım 2, 3 resimden 3.
    • Unscrew the two Torx T2 screws located at the bottom next to the device's micro USB port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
    • Use an iSclack or a suction handle to separate the display unit from the rear panel.
    FixBot'a Sor
  3. Huawei P8 Front Camera Replacement: adım 3, 2 resimden 1. Huawei P8 Front Camera Replacement: adım 3, 2 resimden 2.
    • Remove the Phillips #00 screw that holds down the metal clamp covering the front camera connector.
    • Remove the metal clamp covering the flex connector of the front camera.
    FixBot'a Sor
  4. Huawei P8 Front Camera Replacement: adım 4, 3 resimden 1. Huawei P8 Front Camera Replacement: adım 4, 3 resimden 2. Huawei P8 Front Camera Replacement: adım 4, 3 resimden 3.
    • Unplug the headphone jack and the front camera flex connectors.
    • Remove the front camera.
    FixBot'a Sor
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
258.474 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit EU Team iFixit EU Team üyesi
Staff
37 Üyeler
1.226 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 50
Her zaman: 2,750
