Ana içeriğe geç
Huawei P8 Lite Camera Replacement
Neye ihtiyacın var
  1. Huawei P8 Lite Camera Replacement, Camera: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Spudger
    $2.99
    • Using the Spudger, begin by removing both of the SIM slots from the side of the device.
  2. Huawei P8 Lite Camera Replacement: adım 2, 1 resimden 1.
    Spudger
    $2.99
    • Then remove the back cover of the device with the Spudger. To prevent damage to the back cover, begin removing the cover half an inch to the right of the headphone jack and continue prying around the perimeter of the device.
  3. Huawei P8 Lite Camera Replacement: adım 3, 1 resimden 1.
    T5 Torx Screwdriver
    $9.99
  4. Huawei P8 Lite Camera Replacement: adım 4, 2 resimden 1. Huawei P8 Lite Camera Replacement: adım 4, 2 resimden 2.
    Spudger
    $2.99
    • Use the Spudger to gently remove the Loudspeaker from the device. Place the replacement Loudspeaker into the device and follow these steps in reverse order to reassemble the device.
  5. Huawei P8 Lite Camera Replacement: adım 5, 1 resimden 1.
    • Gently separate the connectors attached to the motherboard.
  6. Huawei P8 Lite Camera Replacement: adım 6, 1 resimden 1.
    • Carefully remove the motherboard from the device.
  7. Huawei P8 Lite Camera Replacement: adım 7, 1 resimden 1.
    Spudger
    $2.99
    • Once the motherboard is removed use the Spudger to remove the Front Camera.
  8. Huawei P8 Lite Camera Replacement: adım 8, 2 resimden 1. Huawei P8 Lite Camera Replacement: adım 8, 2 resimden 2.
    Spudger
    $2.99
    • Similarly, use the Spudger to remove the Rear Camera.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
John Poffenberger
356 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Kass Spring 2017 USF Tampa, Team 1-1, Kass Spring 2017 üyesi
USFT-KASS-S17S1G1
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,465
