Giriş
Use this guide to replace the earpiece speaker of your Huawei P8 Lite.
Neye ihtiyacın var
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
Remove the three Phillips #00 screws that hold the metal plate in place.
Remove the metal plate with a tweezer.
Unplug the battery flex connector with a spudger.
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Bonjour, sur le mien, il y a deux fils de cuivre très très fin, souder sur le haut parleur interne…
