Ana içeriğe geç
Huawei P8 Lite Earpiece Speaker Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Huawei P8 Lite Earpiece Speaker Replacement, Back Cover: adım 1, 2 resimden 1. Huawei P8 Lite Earpiece Speaker Replacement, Back Cover: adım 1, 2 resimden 2.
    • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
  2. Huawei P8 Lite Earpiece Speaker Replacement: adım 2, 3 resimden 1. Huawei P8 Lite Earpiece Speaker Replacement: adım 2, 3 resimden 2. Huawei P8 Lite Earpiece Speaker Replacement: adım 2, 3 resimden 3.
    • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
    • When all clips are open, remove the back cover from the rest of the phone.
    • If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
  3. Huawei P8 Lite Earpiece Speaker Replacement, Loudspeaker: adım 3, 1 resimden 1.
    • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
  4. Huawei P8 Lite Earpiece Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
  5. Huawei P8 Lite Earpiece Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the loudspeaker carefully.
  6. Huawei P8 Lite Earpiece Speaker Replacement, Motherboard: adım 6, 1 resimden 1.
    • Continue by removing the SIM and SD card trays on the side of the device.
  7. Huawei P8 Lite Earpiece Speaker Replacement: adım 7, 3 resimden 1. Huawei P8 Lite Earpiece Speaker Replacement: adım 7, 3 resimden 2. Huawei P8 Lite Earpiece Speaker Replacement: adım 7, 3 resimden 3.
    • Remove the two Torx T5 screws. One may be cover with a liquid indicator.
    • Remove the five Phillips #000 screws.
    • Take away both securing brackets covering the motherboard.
    • If your phone has an NFC antenna, taking away the cover will automatically free its flex connector from the motherboard.
  8. Huawei P8 Lite Earpiece Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the three Phillips #000 screws on the silver panel.
  9. Huawei P8 Lite Earpiece Speaker Replacement: adım 9, 2 resimden 1. Huawei P8 Lite Earpiece Speaker Replacement: adım 9, 2 resimden 2.
    • Carefully separate the four connectors holding the motherboard in place.
    • Remove the motherboard from the device.
  10. Huawei P8 Lite Earpiece Speaker Replacement, Earpiece Speaker: adım 10, 2 resimden 1. Huawei P8 Lite Earpiece Speaker Replacement, Earpiece Speaker: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    $3.99
    • Using the Tweezers, carefully remove the Earpiece Speaker.
    • Insert the new Earpiece Speaker and follow these steps in reverse order to reassemble the device.
Sonuç
Adam Jansen
417 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Kass Spring 2017 USF Tampa, Team 1-1, Kass Spring 2017 üyesi
USFT-KASS-S17S1G1
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 529
