Bu çeviri, kaynak kılavuzdaki en son güncellemeleri yansıtmayabilir. Çeviriyi güncellemeye yardımcı olun veya kaynak kılavuzunu görüntüleyin.
Giriş
Bu kılavuzu, Huawei P8 akıllı telefonunuzun pilini değiştirmek için kullanın.
Neye ihtiyacın var
Öncelikle telefonunuzu kapatın.
SD Kart ve SIM kart tepsilerini çıkartın.
Cihazın altında, Mikro USB girişinin yanında bulunan iki adet Torx T2 vidayı çıkarın.
Torx 2 also works :)
Tried pentalobe drivers but had to get a Torx 2 in the end, possibly some variation across regional models.
Pentalobe screws on my p8…
In the kit,i have only T2…
Cihazınızı tekrar birleştirmek için, bu tamilatları sondan başa doğru uygulayın.
18 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
95%
Gözde dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
9 Yorum
Really helpful guide. Only hiccup was that on my handset the screws holding the casing together (Step 2) were Torx 2 rather than pentalobe, possibly a regional variation. I opted not to remove the loudspeaker (Step 10) as the ribbon cable was firmly stuck down and I worried it would break. This meant I could only cleanly remove the adhesive pad in line with the charging port. I was able to prise out the battery using spudger and screwdriver to scrape the other pad from the phone body. All now reassembled and working properly!
Overall a very helpful guide . I also had torx screws in mine . The torx screws are tiny , so make sure you have the right screwdriver before starting . We didn’t bother removing the loudspeader assembly either (Step 10) . You can just prise up the ribbon cable (carefully) . Add heat if necessary . Now to the biggest problem . Removing the old battery from the phone . What a nightmare ! It’s really stuck down .We took our time using a hairdryer (no heat gun) , and a flat head screwdriver , and went from one end to the other prising it off gently . It still took about 20 minutes . Saying that . Don’t rush it , as it’s the final stage . Also . If you do use a flat head screwdriver then don’t twist it , as you might damage the casing . Just slide it underneath it applying heat . Total time to remove the old battery was 90 minutes , but about 50 of those were spent just getting the first 2 screws out . 20 minutes to put the new battery in and reassemble . Make sure all flex connectors are properly reseated .
My P8 battery has completely died on me. I cannot believe that to replace a battery, we have to now go to these lengths to do it. There must be a mountain of mobile phones, where the only issue with them is a flat battery. Surely, this cannot be allowed to continue. I know why the manufacturers want to make it hard to simply replace a battery, because it sells more mobile phones. But think of all that wasted technology, where a phone may have lasted just over a 24 month contract before the battery is done.
Many thanks for this tutorial. Together we shall beat them!
Thank you for a very nice and easy to follow tutorial!
I have now replaced my battery with what should be an original battery for the Huawei Ascend P8, battery nr: HB3447A9EBW. For some reason the width of the new battery is a few millimeters smaller than the old one, meaning that it does not fill out the space completely. Has anyone else experienced the same?
After having assembled the phone again I experience some weird issues with the battery level dropping from 50%, 60%, 70% or even 100% in an instant. I have tried calibrating the battery by, letting it die completely, recharge it to 100% let it drain completely again and recharge. I have tried different battery calibration apps and a factory reset - nothing helps.
I contacted the company I bought the battery from and got a replacement - still same issue.
Unfortunately i damaged the original battery when taking it out, so i cant use that as a reference.
Any suggestions would be most appreciated!
Most likely you’ve got a fake battery… :( A telling thing can be if the serial does not match the one you can read from the QR code beside it. Only solution would be to get a genuine one. I can feel your pain.
I have the same issue… I open the back cover and unplug the battery flex connector and then reconnect it again… it is OK for some time but when flex connector is loose again… I grtget the same problem… InIn my case… The battery bracket holding the plug tight is lost and hence connection losen after some time… I smam thing to cut a bracket from a Pepsi Cane…
after replacing battery phone doesnt switch on only if charger pluged in does it show the hauwie logo then restart same thing again
