Ana içeriğe geç
Huawei P9 Back Cover
Neye ihtiyacın var
  1. Huawei P9 Back Cover, Back Cover: adım 1, 3 resimden 1. Huawei P9 Back Cover, Back Cover: adım 1, 3 resimden 2. Huawei P9 Back Cover, Back Cover: adım 1, 3 resimden 3.
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Huawei P9 Back Cover: adım 2, 2 resimden 1. Huawei P9 Back Cover: adım 2, 2 resimden 2.
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
    FixBot'a Sor
    Yorum Ekle
  3. Huawei P9 Back Cover, Fingerprint sensor: adım 3, 2 resimden 1. Huawei P9 Back Cover, Fingerprint sensor: adım 3, 2 resimden 2.
    • Disconnect the fingerprint sensor using a spudger.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
134.079 İtibar
189 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
I cant open the phone
Chizu - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 64
Her zaman: 10,192
