Ana içeriğe geç
Huawei P9 Front Facing Camera Replacement
Neye ihtiyacın var
  1. Huawei P9 Front Facing Camera Replacement, Back Cover: adım 1, 3 resimden 1. Huawei P9 Front Facing Camera Replacement, Back Cover: adım 1, 3 resimden 2. Huawei P9 Front Facing Camera Replacement, Back Cover: adım 1, 3 resimden 3.
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Front Facing Camera Replacement: adım 2, 2 resimden 1. Huawei P9 Front Facing Camera Replacement: adım 2, 2 resimden 2.
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Front Facing Camera Replacement, Fingerprint sensor: adım 3, 2 resimden 1. Huawei P9 Front Facing Camera Replacement, Fingerprint sensor: adım 3, 2 resimden 2.
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Front Facing Camera Replacement, Front Facing Camera: adım 4, 3 resimden 1. Huawei P9 Front Facing Camera Replacement, Front Facing Camera: adım 4, 3 resimden 2. Huawei P9 Front Facing Camera Replacement, Front Facing Camera: adım 4, 3 resimden 3.
    • Peel off the conducting fabric.
    • You will have to transfer it to the new camera (careful it's sticky).
    • Unplug the camera connector.
    • Now you can remove the front camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dominik Schnabelrauch
249.753 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit EU Team iFixit EU Team üyesi
Staff
37 Üyeler
1.211 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 1,917
