Ana içeriğe geç
Huawei P9 Headphone Jack Replacement
Neye ihtiyacın var
  1. Huawei P9 Headphone Jack Replacement, Back Cover: adım 1, 3 resimden 1. Huawei P9 Headphone Jack Replacement, Back Cover: adım 1, 3 resimden 2. Huawei P9 Headphone Jack Replacement, Back Cover: adım 1, 3 resimden 3.
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Headphone Jack Replacement: adım 2, 2 resimden 1. Huawei P9 Headphone Jack Replacement: adım 2, 2 resimden 2.
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Headphone Jack Replacement, Fingerprint sensor: adım 3, 2 resimden 1. Huawei P9 Headphone Jack Replacement, Fingerprint sensor: adım 3, 2 resimden 2.
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Headphone Jack Replacement, Headphone Jack: adım 4, 3 resimden 1. Huawei P9 Headphone Jack Replacement, Headphone Jack: adım 4, 3 resimden 2. Huawei P9 Headphone Jack Replacement, Headphone Jack: adım 4, 3 resimden 3.
    • Remove the water indicator on top of the screw.
    • Undo the two Phillips #00 screws.
    • Remove metal bracket (mind the adhesive underneath).
  5. Huawei P9 Headphone Jack Replacement: adım 5, 2 resimden 1. Huawei P9 Headphone Jack Replacement: adım 5, 2 resimden 2.
    • Disconnect the flex cable and remove the headphone jack.
    • The old headphone jack is equipped with a rubber seal, which holds the jack down to the phone. Take it off and put it on the new headphone jack.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
124.495 İtibar
189 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
questo procedimento funziona anche con il modello p9 plus? grazie per l’attenzione
abcde181 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 31
Her zaman: 6,036
