Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Use this guide to replace the loudspeaker in your Huawei P9 Lite.
  1. Use an opening pick to unclip the rear cover, starting from the bottom corner. Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. When the back cover is freed from the adhesive you can pop it off by hand completely.
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. On the bottom of the phone remove the following screws: Three 2.9 mm Phillips #00 screws Four 3.8 mm Phillips #00 screws
    • On the bottom of the phone remove the following screws:
    • Three 2.9 mm Phillips #00 screws
    • Four 3.8 mm Phillips #00 screws
    • Now you can grab the loudspeaker unit and take it out.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
81.992 İtibar
150 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
134 Üyeler
14.939 adet Kılavuz yazıldı
3 Yorum
Was replacing the charging system bt now people can not hear me unless I put on loud speaker
dtotisitswe - Yanıt
Same problem here. Any help?
fabio9999 -
Sir hy how are you. Sir p9lite song speaker not working.
Sufyan Raja - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 83
Her zaman: 8,376
