Ana içeriğe geç
Huawei P9 Lite Loudspeaker Replacement
Neye ihtiyacın var
  1. Huawei P9 Lite Loudspeaker Replacement, Back Cover: adım 1, 2 resimden 1. Huawei P9 Lite Loudspeaker Replacement, Back Cover: adım 1, 2 resimden 2.
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Loudspeaker Replacement: adım 2, 1 resimden 1.
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Loudspeaker Replacement: adım 3, 1 resimden 1.
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: adım 4, 3 resimden 1. Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: adım 4, 3 resimden 2. Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: adım 4, 3 resimden 3.
    • On the bottom of the phone remove the following screws:
    • Three 2.9 mm Phillips #00 screws
    • Four 3.8 mm Phillips #00 screws
    • Now you can grab the loudspeaker unit and take it out.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
119.222 İtibar
189 adet Kılavuz yazıldı
Ekip
3 Yorum
Was replacing the charging system bt now people can not hear me unless I put on loud speaker
dtotisitswe - Yanıt
Same problem here. Any help?
fabio9999 -
Sir hy how are you. Sir p9lite song speaker not working.
Sufyan Raja - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 10,251
