Ana içeriğe geç
Huawei P9 Lite Motherboard Shield Removal
Neye ihtiyacın var
  1. Huawei P9 Lite Motherboard Shield Removal, Back Cover: adım 1, 2 resimden 1. Huawei P9 Lite Motherboard Shield Removal, Back Cover: adım 1, 2 resimden 2.
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Motherboard Shield Removal: adım 2, 1 resimden 1.
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Motherboard Shield Removal: adım 3, 1 resimden 1.
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Motherboard Shield Removal, Motherboard Shield: adım 4, 1 resimden 1.
    • Remove the nine Phillips #00 screws that secure the metal shield plate.
    • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
  5. Huawei P9 Lite Motherboard Shield Removal: adım 5, 2 resimden 1. Huawei P9 Lite Motherboard Shield Removal: adım 5, 2 resimden 2.
    • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
    • Use a spudger to disconnect the fingerprint sensor from the motherboard.
    • Peel the NFC antenna cable off of the metal plate.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
117.504 İtibar
188 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 5,953
