Giriş
Use this guide to replace the rear camera in your Huawei P9 Lite.
Neye ihtiyacın var
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Remove the nine Phillips #00 screws that secure the metal shield plate.
6 farklı kişi bu kılavuzu tamamladı.
2 Yorum
So, i ordered some replacement parts for my huawei p9 lite(Main camera, front camera, usb board), Everything i replaced is working, except for the main camera, the new main camera isn’t working, because when i open my camera app it immediately closes, snapchat shows me an error that says: Snapchat was unable to open the camera app. I made sure that the new main camera isn’t working for some reason, because when i put my original camera back in, everything works, including the new front camera). Am i missing something, could it be a hardware problem or a software problem? Please help, i need advices quick. Thanks.
My mobile phon p9 lite camera removed without strip how to adjust camera in lens??
