Ana içeriğe geç
Huawei P9 Rear Camera Replacement
Neye ihtiyacın var
  1. Huawei P9 Rear Camera Replacement, Back Cover: adım 1, 3 resimden 1. Huawei P9 Rear Camera Replacement, Back Cover: adım 1, 3 resimden 2. Huawei P9 Rear Camera Replacement, Back Cover: adım 1, 3 resimden 3.
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Rear Camera Replacement: adım 2, 2 resimden 1. Huawei P9 Rear Camera Replacement: adım 2, 2 resimden 2.
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Rear Camera Replacement, Fingerprint sensor: adım 3, 2 resimden 1. Huawei P9 Rear Camera Replacement, Fingerprint sensor: adım 3, 2 resimden 2.
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Rear Camera Replacement, Rear Camera: adım 4, 2 resimden 1. Huawei P9 Rear Camera Replacement, Rear Camera: adım 4, 2 resimden 2.
    • Undo the two Phillips #00 screws.
    • Remove the bracket.
    • Mind the connector underneath.
  5. Huawei P9 Rear Camera Replacement: adım 5, 2 resimden 1. Huawei P9 Rear Camera Replacement: adım 5, 2 resimden 2.
    • Release the connector.
    • Loosen the camera from the motherboard and take it away.
Sonuç
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
5 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
231.307 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.670 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 3,638
