Ana içeriğe geç
Huawei Pronto LTE Battery Replacement
Neye ihtiyacın var
  1. Huawei Pronto LTE Battery Replacement, Battery: adım 1, 2 resimden 1. Huawei Pronto LTE Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back cover of your Huawei Pronto LTE using an opening tool.
    • Lift the back cover off of the device after the four corners are unlatched.
    FixBot'a Sor
    Yorum Ekle
  2. Huawei Pronto LTE Battery Replacement: adım 2, 3 resimden 1. Huawei Pronto LTE Battery Replacement: adım 2, 3 resimden 2. Huawei Pronto LTE Battery Replacement: adım 2, 3 resimden 3.
    • Remove the 15 screws on the back of the device using a Phillips #000 screwdriver.
    • Hold the device in place while you are doing this step.
    • Lift the inner cover gently by using a spudger.
    FixBot'a Sor
    Yorum Ekle
  3. Huawei Pronto LTE Battery Replacement: adım 3, 3 resimden 1. Huawei Pronto LTE Battery Replacement: adım 3, 3 resimden 2. Huawei Pronto LTE Battery Replacement: adım 3, 3 resimden 3.
    • Detach the yellow latches along the sides to remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Huawei Pronto LTE Battery Replacement: adım 4, 3 resimden 1. Huawei Pronto LTE Battery Replacement: adım 4, 3 resimden 2. Huawei Pronto LTE Battery Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Ensure that all latches are detached and that there are no extra screws to avoid damaging the motherboard.
    • Use tweezers to gently remove the motherboard from the device.
    FixBot'a Sor
    Yorum Ekle
  5. Huawei Pronto LTE Battery Replacement: adım 5, 3 resimden 1. Huawei Pronto LTE Battery Replacement: adım 5, 3 resimden 2. Huawei Pronto LTE Battery Replacement: adım 5, 3 resimden 3.
    • The battery should be revealed once the motherboard is removed.
    • Lift the battery from the top left corner.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Crystal Edwards
450 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 50
Her zaman: 1,266
