Ana içeriğe geç
Huawei Pronto LTE Rear Camera Replacement
Neye ihtiyacın var
  1. Huawei Pronto LTE Rear Camera Replacement, Rear Camera: adım 1, 3 resimden 1. Huawei Pronto LTE Rear Camera Replacement, Rear Camera: adım 1, 3 resimden 2. Huawei Pronto LTE Rear Camera Replacement, Rear Camera: adım 1, 3 resimden 3.
    • Use an Opening Tool and begin to lever up the back cover of your Huawei Pronto LTE
    • Make sure to do this all around the smartphone.
  2. Huawei Pronto LTE Rear Camera Replacement: adım 2, 1 resimden 1.
    • Remove the back cover.
    • Please keep all the removed smartphone pieces in a safe place. These pieces will be needed later.
  3. Huawei Pronto LTE Rear Camera Replacement: adım 3, 2 resimden 1. Huawei Pronto LTE Rear Camera Replacement: adım 3, 2 resimden 2.
    • Unscrew the fifteen 0.5mm screws with a Phillips #000 screwdriver.
  4. Huawei Pronto LTE Rear Camera Replacement: adım 4, 3 resimden 1. Huawei Pronto LTE Rear Camera Replacement: adım 4, 3 resimden 2. Huawei Pronto LTE Rear Camera Replacement: adım 4, 3 resimden 3.
    • Lift up the connectors with tweezers to disconnect them from the motherboard.
    • Then use the tweezer again to take off the motherboard.
  5. Huawei Pronto LTE Rear Camera Replacement: adım 5, 2 resimden 1. Huawei Pronto LTE Rear Camera Replacement: adım 5, 2 resimden 2.
    • Release the connector.
    • Loosen the camera from the motherboard and take it out with the tweezers.
    • Do not touch the camera with your hands, only use tweezers.
Sonuç
Sonara
171 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 158
