Ana içeriğe geç
Huawei Union Motherboard Replacement
Neye ihtiyacın var
  1. Huawei Union Motherboard Replacement, Battery: adım 1, 2 resimden 1. Huawei Union Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
  2. Huawei Union Motherboard Replacement: adım 2, 2 resimden 1. Huawei Union Motherboard Replacement: adım 2, 2 resimden 2.
    • Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
  3. Huawei Union Motherboard Replacement, Camera Lens Panel: adım 3, 1 resimden 1.
    • Remove the thirteen 3mm Phillips #00 screws from the back panel.
  4. Huawei Union Motherboard Replacement: adım 4, 1 resimden 1.
    • Use the flat end of a spudger to pry off the back panel.
  5. Huawei Union Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove a single 3mm Phillips #00 screw from the motherboard.
  6. Huawei Union Motherboard Replacement: adım 6, 2 resimden 1. Huawei Union Motherboard Replacement: adım 6, 2 resimden 2.
    • Using the flat end of a spudger to disconnect the motherboard ribbon cable.
  7. Huawei Union Motherboard Replacement: adım 7, 1 resimden 1.
    • Firmly hold the second ribbon cable's plastic film cover and pull up to disconnect.
  8. Huawei Union Motherboard Replacement: adım 8, 2 resimden 1. Huawei Union Motherboard Replacement: adım 8, 2 resimden 2.
    • Wedge the flat end of a spudger underneath the motherboard and pry upwards to separate it from the frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brittany Achor
756 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Nance Spring 2018 USF Tampa, Team S1-G1, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G1
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 304
