Ana içeriğe geç
Huawei Union Screen Replacement
Neye ihtiyacın var
    1. Huawei Union Screen Replacement, Battery: adım 1, 2 resimden 1. Huawei Union Screen Replacement, Battery: adım 1, 2 resimden 2.
      • Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
      FixBot'a Sor
      Yorum Ekle
    2. Huawei Union Screen Replacement: adım 2, 2 resimden 1. Huawei Union Screen Replacement: adım 2, 2 resimden 2.
      • Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
      FixBot'a Sor
      Yorum Ekle
    1. Huawei Union Screen Replacement, Camera Lens Panel: adım 3, 1 resimden 1.
      • Remove the thirteen 3mm Phillips #00 screws from the back panel.
      FixBot'a Sor
      Yorum Ekle
    2. Huawei Union Screen Replacement: adım 4, 1 resimden 1.
      • Use the flat end of a spudger to pry off the back panel.
      FixBot'a Sor
      Yorum Ekle
    1. Huawei Union Screen Replacement, Motherboard: adım 5, 1 resimden 1.
      • Remove a single 3mm Phillips #00 screw from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Huawei Union Screen Replacement: adım 6, 2 resimden 1. Huawei Union Screen Replacement: adım 6, 2 resimden 2.
      • Using the flat end of a spudger to disconnect the motherboard ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    3. Huawei Union Screen Replacement: adım 7, 1 resimden 1.
      • Firmly hold the second ribbon cable's plastic film cover and pull up to disconnect.
      FixBot'a Sor
      Yorum Ekle
    4. Huawei Union Screen Replacement: adım 8, 2 resimden 1. Huawei Union Screen Replacement: adım 8, 2 resimden 2.
      • Wedge the flat end of a spudger underneath the motherboard and pry upwards to separate it from the frame.
      FixBot'a Sor
      Yorum Ekle
    1. Huawei Union Screen Replacement, Screen: adım 9, 1 resimden 1.
      • Using an iOpener heat source tool, warm the screen of the phone to loosen adhesive of the screen.
      FixBot'a Sor
      Yorum Ekle
    2. Huawei Union Screen Replacement: adım 10, 2 resimden 1. Huawei Union Screen Replacement: adım 10, 2 resimden 2.
      • Wedge an opening pick underneath the screen and slowly work your way around the screen.
      FixBot'a Sor
      Yorum Ekle
    3. Huawei Union Screen Replacement: adım 11, 2 resimden 1. Huawei Union Screen Replacement: adım 11, 2 resimden 2.
      • Using multiple Opening Picks, work your way around the edges making sure not to place too much pressure at any one point.
      • With each pass, move the Opening Pick further to complete separation.
      FixBot'a Sor
      Yorum Ekle
    4. Huawei Union Screen Replacement: adım 12, 3 resimden 1. Huawei Union Screen Replacement: adım 12, 3 resimden 2. Huawei Union Screen Replacement: adım 12, 3 resimden 3.
      • Once screen is sufficiently separated, holding the sides of the frame firmly, use the Spudger to press through the small access window to the screen at the top let and completely separate the screen from the frame.
      • Do not push too firmly. Screen may break. If screen will not separate, use iOpener heating element again and start over.
      • Do not press too far when separating the screen. There is a small ribbon cable attached to the screen that must be gently drawn through small access window.
      FixBot'a Sor
      Yorum Ekle
    5. Huawei Union Screen Replacement: adım 13, 1 resimden 1.
      • Pull screen away from frame making sure the ribbon cable stays attached.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brittany Achor
783 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Nance Spring 2018 USF Tampa, Team S1-G1, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G1
4 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 901
