Ana içeriğe geç
Huawei Watch Jewel Motherboard Replacement
Neye ihtiyacın var
  1. Huawei Watch Jewel Motherboard Replacement, Strap: adım 1, 2 resimden 1. Huawei Watch Jewel Motherboard Replacement, Strap: adım 1, 2 resimden 2.
    • Begin by laying the watch on a flat, smooth surface.
    • This will prevent the watch screen from suffering damage.
    • Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
  2. Huawei Watch Jewel Motherboard Replacement: adım 2, 2 resimden 1. Huawei Watch Jewel Motherboard Replacement: adım 2, 2 resimden 2.
    • Locate the two springs on the back of your watch.
    • The watch comes with two of these springs on each side of the back-face. These are used to release the straps from the body of the watch.
  3. Huawei Watch Jewel Motherboard Replacement: adım 3, 3 resimden 1. Huawei Watch Jewel Motherboard Replacement: adım 3, 3 resimden 2. Huawei Watch Jewel Motherboard Replacement: adım 3, 3 resimden 3.
    • Use the Flex Extension to push the spring to the right. This will release the strap from the watch head.
  4. Huawei Watch Jewel Motherboard Replacement: adım 4, 1 resimden 1.
    • Carefully pull the strap away from the watch.
  5. Huawei Watch Jewel Motherboard Replacement: adım 5, 2 resimden 1. Huawei Watch Jewel Motherboard Replacement: adım 5, 2 resimden 2.
    • Repeat step 3, this time using the other strap.
  6. Huawei Watch Jewel Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Locate the 4 T3 screws in the back of your watch, and use the T3 Torx Screwdriver to unscrew them.
  7. Huawei Watch Jewel Motherboard Replacement: adım 7, 2 resimden 1. Huawei Watch Jewel Motherboard Replacement: adım 7, 2 resimden 2.
    • Use the Metal Spudger to pry open the back of your watch.
    • Make sure the watch is off and not plugged in when prying into the case with the Metal Spudger to avoid the risk of electric shock.
  8. Huawei Watch Jewel Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the back case.
  9. Huawei Watch Jewel Motherboard Replacement: adım 9, 2 resimden 1. Huawei Watch Jewel Motherboard Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers or a nylon spudger to pry up the four press-fit connectors.
    • The glued-down connector in the middle is harder to remove than the rest. That is perfectly fine.
  10. Huawei Watch Jewel Motherboard Replacement: adım 10, 1 resimden 1.
    • Locate the two Phillips #00 screws holding down the motherboard, and use the Phillips #00 screwdriver to remove them.
    • Ensure to place these screws separately from the Torx screws, as they can easily be mixed up.
  11. Huawei Watch Jewel Motherboard Replacement: adım 11, 1 resimden 1.
    Spudger
    $2.99
    Satın Al
    • Use the Metal Spudger to lift the mother board from the watch.
    • The metal spudger may cause damage to the device, use a black nylon spudger when possible.
  12. Huawei Watch Jewel Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
ngan tran
510 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-3, Passmore Spring 2017 USF Tampa, Team 5-3, Passmore Spring 2017 üyesi
USFT-PASSMORE-S17S5G3
4 Üyeler
3 adet Kılavuz yazıldı
Bir Yorum
where i can i buy Huawei Watch Jewel Motherboard online?
Mao Sereivathanak - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 3,206
