Giriş
In this guide we are going to replace the LCD display on the Huawei ascend Y300 android smartphone. This may be necessary for a damaged screen causing lines, dark spots, and distorted images. The damage may be caused by:
- Physical impacts/pressure
- Heat
- Moisture
- Dust
Before we start it is a good idea to prepare an organized area and a bowl or tray to put the small screws in and prevent them getting lost to carry out the repair.
Neye ihtiyacın var
Remove the rear cover at the back by pulling the gap located at the bottom of the phone.
Lift up and remove the battery.
Bu adımda kullanılan alet:Tweezers$4.99
On the left of the motherboard there is a ribbon cable that connects the volume rocker to the motherboard, we need to disconnect it.
Next using the tweezers carefully pull the ribbon cable away from the socket it was in until it is completely clear of the connector.
44 farklı kişi bu kılavuzu tamamladı.
2 Yorum
good
it a good advise and easy
Its really helpful and so easy ... thanks
