Ana içeriğe geç
Huawei u7519 Back Cover Replacement
Neye ihtiyacın var
  1. Huawei u7519 Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Huawei u7519 Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Take off the back covering of the phone along with the battery and SIM card.
    • The SIM card is located above the battery.
  2. Huawei u7519 Back Cover Replacement: adım 2, 2 resimden 1. Huawei u7519 Back Cover Replacement: adım 2, 2 resimden 2.
    • Using the Phillips #00 Screwdriver, take out the four small screws located at the four corners of the phone.
    • Save the screws. They will be needed for reassembly.
  3. Huawei u7519 Back Cover Replacement: adım 3, 1 resimden 1.
    • Using the same screwdriver, take out the two bigger screws located on each side of the battery compartment.
    • NOTE: Save the screws. They will be needed for reassembly.
  4. Huawei u7519 Back Cover Replacement: adım 4, 1 resimden 1.
    • Once all the screws are removed, use the iPod opening tool to pry off the back covering of the phone along the edge of the back cover and you will have access to the motherboard.
    • Note: The power and volume buttons will fall out of the phone. Set aside for reassembly.
  5. Huawei u7519 Back Cover Replacement: adım 5, 1 resimden 1.
    • Carefully pull the backing of the phone from the motherboard with your hands.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Savanah Anik
65 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-1, Meza Spring 2014 Ohio State, Team 1-1, Meza Spring 2014 üyesi
OSU-MEZA-S14S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 451
