1. Take off the back covering of the phone along with the battery and SIM card. The SIM card is located above the battery.
    • Take off the back covering of the phone along with the battery and SIM card.
    • The SIM card is located above the battery.
  2. Using the Phillips #00 Screwdriver, take out the four small screws located at the four corners of the phone. Save the screws. They will be needed for reassembly.
    • Using the Phillips #00 Screwdriver, take out the four small screws located at the four corners of the phone.
    • Save the screws. They will be needed for reassembly.
  3. Using the same screwdriver, take out the two bigger screws located on each side of the battery compartment.
    • Using the same screwdriver, take out the two bigger screws located on each side of the battery compartment.
    • NOTE: Save the screws. They will be needed for reassembly.
  4. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Once all the screws are removed, use the iPod opening tool to pry off the back covering of the phone along the edge of the back cover and you will have access to the motherboard.
    • Once all the screws are removed, use the iPod opening tool to pry off the back covering of the phone along the edge of the back cover and you will have access to the motherboard.
    • Note: The power and volume buttons will fall out of the phone. Set aside for reassembly.
  6. Carefully pull the backing of the phone from the motherboard with your hands.
    • Carefully pull the backing of the phone from the motherboard with your hands.
  7. To remove front encasing from the motherboard, first pull back the orange tabs. To remove front encasing from the motherboard, first pull back the orange tabs.
    • To remove front encasing from the motherboard, first pull back the orange tabs.
  8. Once the orange tabs are pulled back, carefully pull the motherboard apart from the front casing. Once the orange tabs are pulled back, carefully pull the motherboard apart from the front casing.
    • Once the orange tabs are pulled back, carefully pull the motherboard apart from the front casing.
  9. The camera is not removable from the motherboard. Therefore, a new motherboard must be purchased in order to replace the camera.
    • The camera is not removable from the motherboard. Therefore, a new motherboard must be purchased in order to replace the camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Marcus Mamarella
36 İtibar
1 Kılavuz yazıldı
Takım
Ohio State, Team 1-1, Meza Spring 2014 Ohio State, Team 1-1, Meza Spring 2014 üyesi
OSU-MEZA-S14S1G1
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 419
