Ana içeriğe geç
Huffy Kids Tricycle Seat Replacement
Neye ihtiyacın var
  1. Huffy Kids Tricycle Seat Replacement, Seat: adım 1, 2 resimden 1. Huffy Kids Tricycle Seat Replacement, Seat: adım 1, 2 resimden 2.
    • Focus on the seat area for the replacement.
  2. Huffy Kids Tricycle Seat Replacement: adım 2, 2 resimden 1. Huffy Kids Tricycle Seat Replacement: adım 2, 2 resimden 2.
    • Place the spanner on the bolt on the underside of the seat.
    • Then use a Phillips #2 screwdriver to remove the screw on the top of the seat.
  3. Huffy Kids Tricycle Seat Replacement: adım 3, 3 resimden 1. Huffy Kids Tricycle Seat Replacement: adım 3, 3 resimden 2. Huffy Kids Tricycle Seat Replacement: adım 3, 3 resimden 3.
    • Repeat for the other screw.
  4. Huffy Kids Tricycle Seat Replacement: adım 4, 3 resimden 1. Huffy Kids Tricycle Seat Replacement: adım 4, 3 resimden 2. Huffy Kids Tricycle Seat Replacement: adım 4, 3 resimden 3.
    • Lift the seat off of the trike frame.
  5. Huffy Kids Tricycle Seat Replacement: adım 5, 3 resimden 1. Huffy Kids Tricycle Seat Replacement: adım 5, 3 resimden 2. Huffy Kids Tricycle Seat Replacement: adım 5, 3 resimden 3.
    • Place the new seat on the seat bracket, lining up the screw holes in the seat with the appropriate holes on the bracket.
    • Note that the bracket has two sets of holes for mounting the seat, so choose the appropriate set for the height of the rider. A taller rider will use the further set while a shorter rider will use the set closer to the handlebars.
    • Insert the screws from the top of the seat, using your spanner to hold the nuts under the screws.
  6. Huffy Kids Tricycle Seat Replacement: adım 6, 2 resimden 1. Huffy Kids Tricycle Seat Replacement: adım 6, 2 resimden 2.
    • Give the seat a wiggle to check that it is tight against the bracket.
    • If there is any play, tighten the screws a few more turns.
Sonuç
To reassemble your device, follow these instructions in reverse order and you should be able to accomplish this
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 581
