Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Humax IRHD 5000C cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Humax IRHD 5000C Teardown, open up case: adım 1, 2 resimden 1. Humax IRHD 5000C Teardown, open up case: adım 1, 2 resimden 2.
    • Unscrew the screws on the outside.
    • Slide the top cover a bit to the back, and lift it from the enclosure.
  2. Humax IRHD 5000C Teardown, remove power supply: adım 2, 2 resimden 1. Humax IRHD 5000C Teardown, remove power supply: adım 2, 2 resimden 2.
    • Remove the various pieces holding in the power supply.
    • Remove power cable (already cut of in the photo).
    • Unscrew screws.
    • Disconnect mainboard cables.
    • Remove the power supply from the enclosure.
  3. Humax IRHD 5000C Teardown, remove front: adım 3, 2 resimden 1. Humax IRHD 5000C Teardown, remove front: adım 3, 2 resimden 2.
    • Disconnect the cables connecting the mainboard to the front panel.
    • With a flathead screwdriver, unclip the 2 topside clips, and 3 clips on the bottom of the enclosure, and the front will detach.
  4. Humax IRHD 5000C Teardown, disassemble front: adım 4, 3 resimden 1. Humax IRHD 5000C Teardown, disassemble front: adım 4, 3 resimden 2. Humax IRHD 5000C Teardown, disassemble front: adım 4, 3 resimden 3.
    • Unclip the 4 clips from left to right, and remove the panel.
    • With the pliers, clamp the white connector and push it through.
  5. Humax IRHD 5000C Teardown, remove mainboard: adım 5, 2 resimden 1. Humax IRHD 5000C Teardown, remove mainboard: adım 5, 2 resimden 2.
    • Unscrew the screws and remove the mainboard from the case.
knipwim
15.067 İtibar
43 adet Kılavuz yazıldı
2Kılavuz Yorumları
What are those unsoldered pad connectors for? A hard drive?
Jessica Parnelli Fawkes - Yanıt Paylaş
Don’t know, could be a SCSI drive, there are 68 pins. I included a detail picture in the last step.
knipwim - Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 38
Her zaman: 1,837
