Ana içeriğe geç
Humax RM-H01U Remote Disassembly
Neye ihtiyacın var
  1. Humax RM-H01U Remote Disassembly, The Humax RM-H01U remote: adım 1, 2 resimden 1. Humax RM-H01U Remote Disassembly, The Humax RM-H01U remote: adım 1, 2 resimden 2.
    • The remote has a bottom and top part. They are held together with plastic clips.
    • Don't forget to remove the battery, just for good measure.
    FixBot'a Sor
  2. Humax RM-H01U Remote Disassembly, Opening using a spudger: adım 2, 3 resimden 1. Humax RM-H01U Remote Disassembly, Opening using a spudger: adım 2, 3 resimden 2. Humax RM-H01U Remote Disassembly, Opening using a spudger: adım 2, 3 resimden 3.
    • Use a spudger, prying tool or a flatbed screwdriver to pry open the two halves. Start at the center.
    • The two halves are clamped together firmly.
    • Work your way to the front, and then back again on the other side.
    • See the next step for the location of the clips.
    FixBot'a Sor
  3. Humax RM-H01U Remote Disassembly, Clip locations: adım 3, 1 resimden 1.
    • The clips are located 3 centimeters apart. The first clip is 1 centimeter from the front of the remote.
    • The hooks of the clips are on the bottom halve of the remote and face inward.
    • The top halve of the remote has indents where the clips grab into.
    FixBot'a Sor
  4. Humax RM-H01U Remote Disassembly, All parts of the remote: adım 4, 1 resimden 1.
    • These are all the parts.
    • I cleaned all parts with a toothbrush first.
    • Then I cleaned the PCB and the back of the silicone buttons with pure alcohol.
    • Make sure not to brush too hard! You might remove the carbon layer that is applied. (It's the carbon layer that makes the electrical connection, so it's essential).
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jurrie
763 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 47
Her zaman: 731
