Ana içeriğe geç
Huntington GA41PS-RDS Acoustic Guitar String Replacement
Neye ihtiyacın var
  1. Huntington GA41PS-RDS Acoustic Guitar String Replacement, Guitar String: adım 1, 1 resimden 1.
    • Place your guitar on a flat surface where you can easily identify the broken string.
  2. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 2, 3 resimden 1. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 2, 3 resimden 2. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 2, 3 resimden 3.
    • Rotate the guitar pegs counter clockwise to loosen the broken string, until it can be removed by hand.
  3. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 3, 2 resimden 1. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 3, 2 resimden 2.
    • Remove the bridge pin located at the lower end of the guitar.
    • Remove the other end of the broken string carefully. Keep the bridge pin removed.
  4. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 4, 3 resimden 1. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 4, 3 resimden 2. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 4, 3 resimden 3.
    • Take the ball end of the new string and insert it into the bridge hole.
    • Insert the bridge pin back into the hole. Pull the rest of the string slightly to make sure it is tight.
    • Select the correct string to replace. I will be using the thinnest E string for this guide
  5. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 5, 3 resimden 1. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 5, 3 resimden 2. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 5, 3 resimden 3.
    • Take the pointed end of the string and insert it into the string post.
    • Allow excess string to pass through. Tug on the string and make sure the string is parallel to the fret board.
    • Be careful. Do not hold too close to the sharp end of the string.
  6. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 6, 3 resimden 1. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 6, 3 resimden 2. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 6, 3 resimden 3.
    • Make one loop around the string post with the excess string.
    • Rotate the tuning peg clockwise to tighten the string.
  7. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 7, 2 resimden 1. Huntington GA41PS-RDS Acoustic Guitar String Replacement: adım 7, 2 resimden 2.
    • Trim the excess string with the pliers. Make sure to cut close to the string post so it does not stick out.
Sonuç
Ruhail Khan
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 509
