Ana içeriğe geç
Husqvarna FE 350 Rear Sprocket Replacement
  1. Husqvarna FE 350 Rear Sprocket Replacement, Rear Sprocket: adım 1, 1 resimden 1.
    • Place the motorcycle on a stand so that the rear tire is off the ground.
  2. Husqvarna FE 350 Rear Sprocket Replacement: adım 2, 2 resimden 1. Husqvarna FE 350 Rear Sprocket Replacement: adım 2, 2 resimden 2.
    • Use the 27mm wrench to unscrew the nut that holds the axle together. This nut is located on the right side of the motorcycle at the end of the swing-arm.
  3. Husqvarna FE 350 Rear Sprocket Replacement: adım 3, 3 resimden 1. Husqvarna FE 350 Rear Sprocket Replacement: adım 3, 3 resimden 2. Husqvarna FE 350 Rear Sprocket Replacement: adım 3, 3 resimden 3.
    • Move to the left side of the motorcycle and remove the axle by pulling it directly out.
    • Move back to the right side and remove the spacer shown in the third picture to ensure that is does not get lost.
  4. Husqvarna FE 350 Rear Sprocket Replacement: adım 4, 2 resimden 1. Husqvarna FE 350 Rear Sprocket Replacement: adım 4, 2 resimden 2.
    • Pull up and back on the chain to free the tire.
  5. Husqvarna FE 350 Rear Sprocket Replacement: adım 5, 1 resimden 1.
    • Lay the tire on a flat surface with with sprocket facing up.
    • Use the 6mm Torx wrench to unscrew the six bolts holding the sprocket on.
    • Replace the sprocket and screw the bolts back in.
  6. Husqvarna FE 350 Rear Sprocket Replacement: adım 6, 1 resimden 1.
    • Be careful that the brake rotor fits in between the brake pads on the caliper.
  7. Husqvarna FE 350 Rear Sprocket Replacement: adım 7, 1 resimden 1.
    • Put the chain back on. Start at the bottom and work the chain carefully over the top of the new sprocket.
  8. Husqvarna FE 350 Rear Sprocket Replacement: adım 8, 3 resimden 1. Husqvarna FE 350 Rear Sprocket Replacement: adım 8, 3 resimden 2. Husqvarna FE 350 Rear Sprocket Replacement: adım 8, 3 resimden 3.
    • Push the axle back through the swing arm and the wheel.
    • Place the spacer back onto the axle with the square side pointing forward.
    • Thread the 27mm nut back onto the axle.
  9. Husqvarna FE 350 Rear Sprocket Replacement: adım 9, 1 resimden 1.
    • Use the 27mm wrench to tighten the nut down.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 56
Her zaman: 436
