Ana içeriğe geç
Husqvarna Trimmer Carburetor Replacement
Neye ihtiyacın var
  1. Husqvarna Trimmer Carburetor Replacement, Husqvarna Trimmer Carburetor: adım 1, 1 resimden 1.
    • Allow time for the engine to cool before beginning this procedure.
    • Using your fingers, unscrew the air filter bolt and remove it from the filter cover.
  2. Husqvarna Trimmer Carburetor Replacement: adım 2, 3 resimden 1. Husqvarna Trimmer Carburetor Replacement: adım 2, 3 resimden 2. Husqvarna Trimmer Carburetor Replacement: adım 2, 3 resimden 3.
    • Pull off the filter cover to reveal the air filter.
    • Remove the air filter from the filter housing.
  3. Husqvarna Trimmer Carburetor Replacement: adım 3, 2 resimden 1. Husqvarna Trimmer Carburetor Replacement: adım 3, 2 resimden 2.
    • Remove two 8mm nuts with an 8mm socket attached to a 1/4" ratchet turning the nuts counterclockwise.
  4. Husqvarna Trimmer Carburetor Replacement: adım 4, 2 resimden 1. Husqvarna Trimmer Carburetor Replacement: adım 4, 2 resimden 2.
    • Slide the choke lever to the full choke position.
  5. Husqvarna Trimmer Carburetor Replacement: adım 5, 3 resimden 1. Husqvarna Trimmer Carburetor Replacement: adım 5, 3 resimden 2. Husqvarna Trimmer Carburetor Replacement: adım 5, 3 resimden 3.
    • Remove the plastic housing by pulling it away from the device.
  6. Husqvarna Trimmer Carburetor Replacement: adım 6, 2 resimden 1. Husqvarna Trimmer Carburetor Replacement: adım 6, 2 resimden 2.
    • Pull the carburetor off of the bolts.
  7. Husqvarna Trimmer Carburetor Replacement: adım 7, 3 resimden 1. Husqvarna Trimmer Carburetor Replacement: adım 7, 3 resimden 2. Husqvarna Trimmer Carburetor Replacement: adım 7, 3 resimden 3.
    • Detach the throttle cable from the carburetor by tilting it 90 degrees and pulling up.
  8. Husqvarna Trimmer Carburetor Replacement: adım 8, 2 resimden 1. Husqvarna Trimmer Carburetor Replacement: adım 8, 2 resimden 2.
    • Remove the two fuel lines attached to the bottom of the carburetor using a set of needle nose pliers.
    • Gas may splash when removing fuel lines.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 63
Her zaman: 2,116
