Ana içeriğe geç
Hydration Bladder Leak Repair
Neye ihtiyacın var
  1. Hydration Bladder Leak Repair, Hydration Bladder Leak Repair: adım 1, 1 resimden 1.
    • Remove the hydration bladder from inside the backpack.
  2. Hydration Bladder Leak Repair: adım 2, 1 resimden 1.
    • Check the bladder and pipe to locate any scratches or leaks.
    • It may help to fill the bladder up with water to check for additional tiny leaks which could be harder to locate than leaks on the pipe.
  3. Hydration Bladder Leak Repair: adım 3, 1 resimden 1.
    • Rinse out the pipe to clear any clogs.
  4. Hydration Bladder Leak Repair: adım 4, 1 resimden 1.
    • Cut appropriate size tenacious tape to patch the leak on the bladder.
  5. Hydration Bladder Leak Repair: adım 5, 1 resimden 1.
    • Seal the leak on the bladder with tenacious tape.
    • Do not try to use regular tape as it will not seal correctly.
    • Smooth out all the edges and apply pressure for approximately one to two minutes.
  6. Hydration Bladder Leak Repair: adım 6, 1 resimden 1.
    • Slide the heat shrink tube over the pipe and hold tightly in place over the ruptured area.
  7. Hydration Bladder Leak Repair: adım 7, 2 resimden 1. Hydration Bladder Leak Repair: adım 7, 2 resimden 2.
    • Using a hair dryer, apply heat to shrink the tube until it is tightly sealed in place.
    • This process may take 20-35 minutes depending on the power of your heat source.
  8. Hydration Bladder Leak Repair: adım 8, 1 resimden 1.
    • Reinsert the pipe back into the bladder and twist lock it back into place as shown.
    • Make sure you feel it snap back into place and listen for a "click" sound.
  9. Hydration Bladder Leak Repair: adım 9, 1 resimden 1.
    • Slide the bladder itself back into backpack and pull the pipe out through the opening as indicated and your bag is good to go!
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Magnolia Garcia
178 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S2-G7, Bender Fall 2018 UC Davis, Team S2-G7, Bender Fall 2018 üyesi
UCD-BENDER-F18S2G7
4 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 22
Son 30 gün: 107
Her zaman: 9,858
