Ana içeriğe geç
HyperX Alloy Origins Backplate Replacement
  1. HyperX Alloy Origins Backplate Replacement, Toggle Indicator Tab: adım 1, 1 resimden 1.
    • Locate the toggle indicator tab on the top right corner of the keyboard.
  2. HyperX Alloy Origins Backplate Replacement: adım 2, 2 resimden 1. HyperX Alloy Origins Backplate Replacement: adım 2, 2 resimden 2.
    • Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
    • Lift up gently on the tab, while holding the left side of the tab down.
    • The tab can spring upwards upon removal. Eye protection is recommended during this step.
  3. HyperX Alloy Origins Backplate Replacement, Backplate: adım 3, 2 resimden 1. HyperX Alloy Origins Backplate Replacement, Backplate: adım 3, 2 resimden 2.
    • Flip the keyboard over so that the backplate is facing you.
  4. HyperX Alloy Origins Backplate Replacement: adım 4, 3 resimden 1. HyperX Alloy Origins Backplate Replacement: adım 4, 3 resimden 2. HyperX Alloy Origins Backplate Replacement: adım 4, 3 resimden 3.
    • Remove the rubber feet on the four corners of the backplate.
    • When reassembling, use an adhesive to reattach the feet. A silicone rubber adhesive is recommended.
  5. HyperX Alloy Origins Backplate Replacement: adım 5, 3 resimden 1. HyperX Alloy Origins Backplate Replacement: adım 5, 3 resimden 2. HyperX Alloy Origins Backplate Replacement: adım 5, 3 resimden 3.
    • Remove the specified keycaps as depicted in the image.
  6. HyperX Alloy Origins Backplate Replacement: adım 6, 3 resimden 1. HyperX Alloy Origins Backplate Replacement: adım 6, 3 resimden 2. HyperX Alloy Origins Backplate Replacement: adım 6, 3 resimden 3.
    • Remove all Philips #0 screws from the new openings created after removing the rubber feet and plastic tab.
  7. HyperX Alloy Origins Backplate Replacement: adım 7, 3 resimden 1. HyperX Alloy Origins Backplate Replacement: adım 7, 3 resimden 2. HyperX Alloy Origins Backplate Replacement: adım 7, 3 resimden 3.
    • Separate the backplate from the keyboard using your hands.
Sonuç
Mario Ricci
255 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S5G2
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 333
