Ana içeriğe geç
HyperX Cloud Alpha Hinges Replacement
Neye ihtiyacın var
  1. HyperX Cloud Alpha Hinges Replacement, Hinges: adım 1, 2 resimden 1. HyperX Cloud Alpha Hinges Replacement, Hinges: adım 1, 2 resimden 2.
    • Remove the two screws attaching the hinge to the back side of the speakers with a Philips #1 screwdriver.
  2. HyperX Cloud Alpha Hinges Replacement: adım 2, 1 resimden 1.
    • Remove the broken hinge from the speaker.
  3. HyperX Cloud Alpha Hinges Replacement: adım 3, 2 resimden 1. HyperX Cloud Alpha Hinges Replacement: adım 3, 2 resimden 2.
    • Remove the two screws from the clips attaching the hinges to the headband. This will free the hinge.
    • To replace the other hinge, repeat Steps 1-3 on the other side.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Shania
137 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Sinclaire Fall 2022 UMass Dartmouth, Team 5-4, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S5G4
5 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
you went and posted the screwdriver in the part we need but you didnt include the most important thing the replacement hinge to replace the broken hinge...
Branden Tomaino - Yanıt
I need to change them on my headset. How do i deal with the wire that goes through the plastic part ? Is there some soldering needed ?
Adelino Antunes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 30
Son 30 gün: 100
Her zaman: 3,314
