Ana içeriğe geç
HyperX Cloud Alpha Hinges Replacement
Neye ihtiyacın var
  1. HyperX Cloud Alpha Hinges Replacement, Hinges: adım 1, 2 resimden 1. HyperX Cloud Alpha Hinges Replacement, Hinges: adım 1, 2 resimden 2.
    • Remove the two screws attaching the hinge to the back side of the speakers with a Philips #1 screwdriver.
  2. HyperX Cloud Alpha Hinges Replacement: adım 2, 1 resimden 1.
    • Remove the broken hinge from the speaker.
  3. HyperX Cloud Alpha Hinges Replacement: adım 3, 2 resimden 1. HyperX Cloud Alpha Hinges Replacement: adım 3, 2 resimden 2.
    • Remove the two screws from the clips attaching the hinges to the headband. This will free the hinge.
    • To replace the other hinge, repeat Steps 1-3 on the other side.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Shania
137 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Sinclaire Fall 2022 UMass Dartmouth, Team 5-4, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S5G4
5 Üyeler
8 adet Kılavuz yazıldı
2Kılavuz Yorumları
you went and posted the screwdriver in the part we need but you didnt include the most important thing the replacement hinge to replace the broken hinge...
Branden Tomaino - Yanıt
I need to change them on my headset. How do i deal with the wire that goes through the plastic part ? Is there some soldering needed ?
Adelino Antunes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 35
Son 30 gün: 134
Her zaman: 3,368
