Ana içeriğe geç
HyperX CloudX Flight Charging Port Replacement
Neye ihtiyacın var
  1. HyperX CloudX Flight Charging Port Replacement, Charging Port: adım 1, 1 resimden 1.
    • Place the device on a flat surface and orient the ear cups towards yourself.
  2. HyperX CloudX Flight Charging Port Replacement: adım 2, 2 resimden 1. HyperX CloudX Flight Charging Port Replacement: adım 2, 2 resimden 2.
    • Gently pull around the perimeter of the left ear cup until the cushion is fully removed.
  3. HyperX CloudX Flight Charging Port Replacement: adım 3, 1 resimden 1.
    • Use a small Phillips screwdriver to remove the base plate.
  4. HyperX CloudX Flight Charging Port Replacement: adım 4, 1 resimden 1.
    • After removing the plate, locate the charging port on the board. You can carefully desolder the charging port from the board by pointing the tip of your soldering iron to melt the existing connections.
Sonuç
To reassemble your device, follow these instructions in reverse order. Ensure to carefully resolder the USB port as to not interfere with other connections.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 46
Her zaman: 90
