Ana içeriğe geç
HyperX CloudX Flight Volume Wheel Replacement
Neye ihtiyacın var
  1. HyperX CloudX Flight Volume Wheel Replacement, Volume Wheel: adım 1, 2 resimden 1. HyperX CloudX Flight Volume Wheel Replacement, Volume Wheel: adım 1, 2 resimden 2.
    • Gently pull around the perimeter of the left ear cup until the cushion is fully removed.
  2. HyperX CloudX Flight Volume Wheel Replacement: adım 2, 1 resimden 1.
    • Unscrew the top of the speaker with a Phillips head screwdriver.
  3. HyperX CloudX Flight Volume Wheel Replacement: adım 3, 1 resimden 1.
    • After taking off the top of the speaker, you will find the volume wheel wedged under the chip.
    • Lift the chip slightly and the volume wheel should slip right out with a bit of pressure.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 42
Her zaman: 105
