Ana içeriğe geç
HyperX QuadCast S Pop Filter Replacement
    1. HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: adım 1, 3 resimden 1. HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: adım 1, 3 resimden 2. HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: adım 1, 3 resimden 3.
      • Set the microphone on a flat surface.
      • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
      • There are four support bands in total, but it does not matter which band you choose to take off first.
      FixBot'a Sor
      Yorum Ekle
    2. HyperX QuadCast S Pop Filter Replacement: adım 2, 3 resimden 1. HyperX QuadCast S Pop Filter Replacement: adım 2, 3 resimden 2. HyperX QuadCast S Pop Filter Replacement: adım 2, 3 resimden 3.
      • Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion.
      • Be careful not to damage the cable as you remove the top.
      • Once the tap-to-mute sensor detaches from the microphone, you will hear a small "pop."
      FixBot'a Sor
      Yorum Ekle
    3. HyperX QuadCast S Pop Filter Replacement: adım 3, 3 resimden 1. HyperX QuadCast S Pop Filter Replacement: adım 3, 3 resimden 2. HyperX QuadCast S Pop Filter Replacement: adım 3, 3 resimden 3.
      • Gently unplug the cable, and remove the tap to the Tap-To-Mute sensor from the microphone.
      • The square indicates the location of the cable. This is cable is very small and will require a bit of force to be unplugged.
      FixBot'a Sor
      Yorum Ekle
    1. HyperX QuadCast S Pop Filter Replacement, Pop Filter: adım 4, 1 resimden 1.
      • Once the Tap-To-Mute sensor has been removed, you will now have access to the pop filter.
      • The pop filter is just the grey foam surrounding the inside of the microphone.
      FixBot'a Sor
      Yorum Ekle
    2. HyperX QuadCast S Pop Filter Replacement: adım 5, 1 resimden 1.
      • The pop filter will be in a fixed position being glued to the wire. Remove glue residue before continuing to remove the pop filter.
      • When you replace the pop filter, remember that you will need to glue it back into place as before.
      FixBot'a Sor
      Yorum Ekle
    3. HyperX QuadCast S Pop Filter Replacement: adım 6, 2 resimden 1. HyperX QuadCast S Pop Filter Replacement: adım 6, 2 resimden 2.
      • Reach into the microphone and remove the pop filter.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathan Arruda
765 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S4G1
5 Üyeler
15 adet Kılavuz yazıldı
3Kılavuz Yorumları
"Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion."
This part is keyed. It literally cannot be pulled in any rotational motion...
Kyle Villalovos - Yanıt Paylaş
Is there a place where you recomend i can get a replacement peice of foam for the pop filter. I cant find one anywhere online.
Liam Henesy - Yanıt Paylaş
did you happen to find anything?
Kamen C-Swartz - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 40
Son 30 gün: 112
Her zaman: 4,520
