Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Push in the release button and pull up on the battery to remove.
Twist antenna counter-clockwise and set damaged antenna aside.
Remove the volume knob by firmly lifting up on both sides of it.
Bu adımda kullanılan alet:Tweezers$4.99-
Remove the orange o-ring around volume knob using tweezers.
Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
Remove the two 15mm T8 Torx screws from the base of the battery cavity.
Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
Bir başkası bu kılavuzu tamamladı.
