Ana içeriğe geç
Hytera TC-580 Microphone Replacement
Neye ihtiyacın var
  1. Hytera TC-580 Microphone Replacement, Battery: adım 1, 2 resimden 1. Hytera TC-580 Microphone Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two 10mm Phillips #0 from the belt clip.
    FixBot'a Sor
    Yorum Ekle
  2. Hytera TC-580 Microphone Replacement: adım 2, 2 resimden 1. Hytera TC-580 Microphone Replacement: adım 2, 2 resimden 2.
    • Push in the release button and pull up on the battery to remove.
    FixBot'a Sor
    Yorum Ekle
  3. Hytera TC-580 Microphone Replacement, Antenna: adım 3, 1 resimden 1.
    • Twist antenna counter-clockwise and set damaged antenna aside.
    FixBot'a Sor
    Yorum Ekle
  4. Hytera TC-580 Microphone Replacement, Keypad: adım 4, 1 resimden 1.
    • Remove the volume knob by firmly lifting up on both sides of it.
    FixBot'a Sor
    Yorum Ekle
  5. Hytera TC-580 Microphone Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the orange o-ring around volume knob using tweezers.
    FixBot'a Sor
    Yorum Ekle
  6. Hytera TC-580 Microphone Replacement: adım 6, 1 resimden 1.
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
    FixBot'a Sor
    Yorum Ekle
  7. Hytera TC-580 Microphone Replacement: adım 7, 1 resimden 1.
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
    FixBot'a Sor
    Yorum Ekle
  8. Hytera TC-580 Microphone Replacement: adım 8, 2 resimden 1. Hytera TC-580 Microphone Replacement: adım 8, 2 resimden 2.
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
    FixBot'a Sor
    Yorum Ekle
  9. Hytera TC-580 Microphone Replacement: adım 9, 1 resimden 1.
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
    FixBot'a Sor
    Yorum Ekle
  10. Hytera TC-580 Microphone Replacement: adım 10, 1 resimden 1.
    • Peel off the keypad by hand.
    FixBot'a Sor
    Yorum Ekle
  11. Hytera TC-580 Microphone Replacement, Speaker: adım 11, 3 resimden 1. Hytera TC-580 Microphone Replacement, Speaker: adım 11, 3 resimden 2. Hytera TC-580 Microphone Replacement, Speaker: adım 11, 3 resimden 3.
    • Remove eleven 4mm Phillips #00 screws.
    FixBot'a Sor
    Yorum Ekle
  12. Hytera TC-580 Microphone Replacement: adım 12, 1 resimden 1.
    • Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
    FixBot'a Sor
    Yorum Ekle
  13. Hytera TC-580 Microphone Replacement, Microphone: adım 13, 1 resimden 1.
    • If not already done, remove the circuit board completely from the case.
    FixBot'a Sor
    Yorum Ekle
  14. Hytera TC-580 Microphone Replacement: adım 14, 1 resimden 1.
    • Desolder the two microphone solder joints.
    FixBot'a Sor
    Yorum Ekle
  15. Hytera TC-580 Microphone Replacement: adım 15, 1 resimden 1.
    • The microphone should fall out after all the solder has been removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Stuart
485 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G4, Nance Spring 2018 USF Tampa, Team S3-G4, Nance Spring 2018 üyesi
USFT-NANCE-S18S3G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 26
Her zaman: 1,202
