Ana içeriğe geç
Hytera TC-580 Speaker Replacement
Neye ihtiyacın var
  1. Hytera TC-580 Speaker Replacement, Battery: adım 1, 2 resimden 1. Hytera TC-580 Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two 10mm Phillips #0 from the belt clip.
  2. Hytera TC-580 Speaker Replacement: adım 2, 2 resimden 1. Hytera TC-580 Speaker Replacement: adım 2, 2 resimden 2.
    • Push in the release button and pull up on the battery to remove.
  3. Hytera TC-580 Speaker Replacement, Antenna: adım 3, 1 resimden 1.
    • Twist antenna counter-clockwise and set damaged antenna aside.
  4. Hytera TC-580 Speaker Replacement, Keypad: adım 4, 1 resimden 1.
    • Remove the volume knob by firmly lifting up on both sides of it.
  5. Hytera TC-580 Speaker Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the orange o-ring around volume knob using tweezers.
  6. Hytera TC-580 Speaker Replacement: adım 6, 1 resimden 1.
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
  7. Hytera TC-580 Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
  8. Hytera TC-580 Speaker Replacement: adım 8, 2 resimden 1. Hytera TC-580 Speaker Replacement: adım 8, 2 resimden 2.
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
  9. Hytera TC-580 Speaker Replacement: adım 9, 1 resimden 1.
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
  10. Hytera TC-580 Speaker Replacement: adım 10, 1 resimden 1.
    • Peel off the keypad by hand.
  11. Hytera TC-580 Speaker Replacement, Speaker: adım 11, 3 resimden 1. Hytera TC-580 Speaker Replacement, Speaker: adım 11, 3 resimden 2. Hytera TC-580 Speaker Replacement, Speaker: adım 11, 3 resimden 3.
    • Remove eleven 4mm Phillips #00 screws.
  12. Hytera TC-580 Speaker Replacement: adım 12, 1 resimden 1.
    • Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
Sonuç
Mohammed Chehab
88 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G4, Nance Spring 2018 USF Tampa, Team S3-G4, Nance Spring 2018 üyesi
USFT-NANCE-S18S3G4
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 525
