Ana içeriğe geç
Hyundai Santa Fe Sport Brake Light Replacement
Neye ihtiyacın var
  1. Hyundai Santa Fe Sport Brake Light Replacement, Brake Light: adım 1, 3 resimden 1. Hyundai Santa Fe Sport Brake Light Replacement, Brake Light: adım 1, 3 resimden 2. Hyundai Santa Fe Sport Brake Light Replacement, Brake Light: adım 1, 3 resimden 3.
    • Open the trunk.
    • Remove the black plastic cover located on the inner side taillight by using a #2 flat head screwdriver.
    • Make sure to pry it off gently to avoid cracking the plastic cover.
  2. Hyundai Santa Fe Sport Brake Light Replacement: adım 2, 3 resimden 1. Hyundai Santa Fe Sport Brake Light Replacement: adım 2, 3 resimden 2. Hyundai Santa Fe Sport Brake Light Replacement: adım 2, 3 resimden 3.
    • Remove the two 12 mm Phillips # 2 screws holding the taillight in place.
  3. Hyundai Santa Fe Sport Brake Light Replacement: adım 3, 1 resimden 1.
    • Slide out the headlights placing one hand on the outer side and the other hand gripped onto the back of the taillight, pulling straight out.
    • For easier removal, press down with force on the outer side of the headlight.
  4. Hyundai Santa Fe Sport Brake Light Replacement: adım 4, 3 resimden 1. Hyundai Santa Fe Sport Brake Light Replacement: adım 4, 3 resimden 2. Hyundai Santa Fe Sport Brake Light Replacement: adım 4, 3 resimden 3.
    • Turn the grey brake light socket with the multi-colored wires connected to it counterclockwise.
  5. Hyundai Santa Fe Sport Brake Light Replacement: adım 5, 2 resimden 1. Hyundai Santa Fe Sport Brake Light Replacement: adım 5, 2 resimden 2.
    • Pull out the light bulb from the grey bulb socket by pushing downwards while turning counterclockwise.
  6. Hyundai Santa Fe Sport Brake Light Replacement: adım 6, 2 resimden 1. Hyundai Santa Fe Sport Brake Light Replacement: adım 6, 2 resimden 2.
    • Take the new replacement bulb and insert it into the light socket while pushing down onto the bulb, turning clockwise and securing the bulb in place.
  7. Hyundai Santa Fe Sport Brake Light Replacement: adım 7, 2 resimden 1. Hyundai Santa Fe Sport Brake Light Replacement: adım 7, 2 resimden 2.
    • Slide the light socket back into the circular compartment, making sure the bulb is facing inwards.
    • After inserted, turn it clockwise to lock the bulb back into place.
  8. Hyundai Santa Fe Sport Brake Light Replacement: adım 8, 3 resimden 1. Hyundai Santa Fe Sport Brake Light Replacement: adım 8, 3 resimden 2. Hyundai Santa Fe Sport Brake Light Replacement: adım 8, 3 resimden 3.
    • Slide the taillight back into the starting position.
    • Align the taillight with a circular piece on the outer side of the car.
    • Use moderate force while sliding the taillight, making sure screw holes are visible.
    • Make sure the grey circular piece on the side is aligned with the taillight to avoid damaging the taillight.
  9. Hyundai Santa Fe Sport Brake Light Replacement: adım 9, 2 resimden 1. Hyundai Santa Fe Sport Brake Light Replacement: adım 9, 2 resimden 2.
    • Take the two 12 mm Phillip #2 screws and place them back into the two visible holes.
  10. Hyundai Santa Fe Sport Brake Light Replacement: adım 10, 3 resimden 1. Hyundai Santa Fe Sport Brake Light Replacement: adım 10, 3 resimden 2. Hyundai Santa Fe Sport Brake Light Replacement: adım 10, 3 resimden 3.
    • Replace the plastic cover by pushing down on all of the corners.
    • Once the plastic piece is fixed onto the car, you can then close the trunk.
    • The plastic piece is secure when all the sides are lined up with the car and taillight.
    • Avoid applying a significant amount of force to prevent cracks in the plastic.
Sonuç
You have now completed the guide, to replace the brake bulb on your 2012 - 2018 Hyundai Santa Fe Sport.
5 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Very good examples and explanation! Wonder if there is a post for the inner tailgate lights as well?
Kenneth - Yanıt
Follow these steps and you can't go wrong. Nicely done.
Chris Talley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 60
Son 30 gün: 273
Her zaman: 16,697
