Ana içeriğe geç
Giriş
This is a step by step guide to removing the keyboard cover of an IBM ThinkPad 560z. The keyboard cover is most commonly removed to facilitate the cleaning or replacement of the keyboard.
Parçalar
Hiçbir parça belirtilmedi.
  1. IBM ThinkPad 560z Keyboard Cover Replacement, Upper Case: adım 1, 1 resimden 1.
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  2. IBM ThinkPad 560z Keyboard Cover Replacement: adım 2, 2 resimden 1. IBM ThinkPad 560z Keyboard Cover Replacement: adım 2, 2 resimden 2.
    • Open the flap on the left hand side.
  3. IBM ThinkPad 560z Keyboard Cover Replacement: adım 3, 2 resimden 1. IBM ThinkPad 560z Keyboard Cover Replacement: adım 3, 2 resimden 2.
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  4. IBM ThinkPad 560z Keyboard Cover Replacement: adım 4, 2 resimden 1. IBM ThinkPad 560z Keyboard Cover Replacement: adım 4, 2 resimden 2.
    • Open the flap on the right side.
  5. IBM ThinkPad 560z Keyboard Cover Replacement: adım 5, 1 resimden 1.
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  6. IBM ThinkPad 560z Keyboard Cover Replacement: adım 6, 2 resimden 1. IBM ThinkPad 560z Keyboard Cover Replacement: adım 6, 2 resimden 2.
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  7. IBM ThinkPad 560z Keyboard Cover Replacement: adım 7, 1 resimden 1.
    • Use your fingers or a spudger to detach the connector.
  8. IBM ThinkPad 560z Keyboard Cover Replacement: adım 8, 2 resimden 1. IBM ThinkPad 560z Keyboard Cover Replacement: adım 8, 2 resimden 2.
    • Carefully lift and remove the keyboard.
Sonuç
Derek Driscoll
119 İtibar
8 adet Kılavuz yazıldı
Takım
Cal Poly, Team 26-27, Regan Spring 2010 Cal Poly, Team 26-27, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G27
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,677
