Ana içeriğe geç
IBM ThinkPad 560z Keyboard Replacement
Neye ihtiyacın var
  1. IBM ThinkPad 560z Keyboard Replacement, Upper Case: adım 1, 1 resimden 1.
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  2. IBM ThinkPad 560z Keyboard Replacement: adım 2, 2 resimden 1. IBM ThinkPad 560z Keyboard Replacement: adım 2, 2 resimden 2.
    • Open the flap on the left hand side.
  3. IBM ThinkPad 560z Keyboard Replacement: adım 3, 2 resimden 1. IBM ThinkPad 560z Keyboard Replacement: adım 3, 2 resimden 2.
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  4. IBM ThinkPad 560z Keyboard Replacement: adım 4, 2 resimden 1. IBM ThinkPad 560z Keyboard Replacement: adım 4, 2 resimden 2.
    • Open the flap on the right side.
  5. IBM ThinkPad 560z Keyboard Replacement: adım 5, 1 resimden 1.
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  6. IBM ThinkPad 560z Keyboard Replacement: adım 6, 2 resimden 1. IBM ThinkPad 560z Keyboard Replacement: adım 6, 2 resimden 2.
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  7. IBM ThinkPad 560z Keyboard Replacement: adım 7, 1 resimden 1.
    • Use your fingers or a spudger to detach the connector.
  8. IBM ThinkPad 560z Keyboard Replacement: adım 8, 2 resimden 1. IBM ThinkPad 560z Keyboard Replacement: adım 8, 2 resimden 2.
    • Carefully lift and remove the keyboard.
  9. IBM ThinkPad 560z Keyboard Replacement, Keyboard Removal: adım 9, 2 resimden 1. IBM ThinkPad 560z Keyboard Replacement, Keyboard Removal: adım 9, 2 resimden 2.
    • Remove the five Phillips screws from the underside of the keyboard, then gently lift it up.
Sonuç
Derek Driscoll
119 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-27, Regan Spring 2010 Cal Poly, Team 26-27, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G27
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 2,451
