Ana içeriğe geç
IBM ThinkPad 560z Screen Replacement
Neye ihtiyacın var
  1. IBM ThinkPad 560z Screen Replacement, Battery Removal: adım 1, 1 resimden 1.
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
    FixBot'a Sor
    Yorum Ekle
  2. IBM ThinkPad 560z Screen Replacement, Screw Cover Removal: adım 2, 2 resimden 1. IBM ThinkPad 560z Screen Replacement, Screw Cover Removal: adım 2, 2 resimden 2.
    • Remove the plastic screw covers, then remove the 3 Phillips screws under them.
    FixBot'a Sor
    Yorum Ekle
  3. IBM ThinkPad 560z Screen Replacement, Screen Bezel Removal: adım 3, 1 resimden 1.
    • Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
    FixBot'a Sor
    Yorum Ekle
  4. IBM ThinkPad 560z Screen Replacement, LCD Removal Preperation: adım 4, 1 resimden 1.
    • Remove the four Phillips head screws.
    FixBot'a Sor
    Yorum Ekle
  5. IBM ThinkPad 560z Screen Replacement, Ribbon Cable Disconnection: adım 5, 1 resimden 1.
    • Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
    FixBot'a Sor
    Yorum Ekle
  6. IBM ThinkPad 560z Screen Replacement, LCD Removal: adım 6, 2 resimden 1. IBM ThinkPad 560z Screen Replacement, LCD Removal: adım 6, 2 resimden 2.
    • Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
    • The connector is very fragile, so be careful.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
John Allande
64 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 26-27, Regan Spring 2010 Cal Poly, Team 26-27, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G27
3 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 5,416
