Ana içeriğe geç
IBM ThinkPad 600E Display Replacement
Neye ihtiyacın var
  1. IBM ThinkPad 600E Display Replacement, Battery: adım 1, 3 resimden 1. IBM ThinkPad 600E Display Replacement, Battery: adım 1, 3 resimden 2. IBM ThinkPad 600E Display Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the laptop over and find the battery latch.
    FixBot'a Sor
  2. IBM ThinkPad 600E Display Replacement: adım 2, 1 resimden 1.
    • Move the latch to the side with the unlocked symbol.
    FixBot'a Sor
  3. IBM ThinkPad 600E Display Replacement: adım 3, 3 resimden 1. IBM ThinkPad 600E Display Replacement: adım 3, 3 resimden 2. IBM ThinkPad 600E Display Replacement: adım 3, 3 resimden 3.
    • Pry the battery out using your fingers.
    FixBot'a Sor
  4. IBM ThinkPad 600E Display Replacement, Keyboard: adım 4, 3 resimden 1. IBM ThinkPad 600E Display Replacement, Keyboard: adım 4, 3 resimden 2. IBM ThinkPad 600E Display Replacement, Keyboard: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Use an antistatic wrist strap to avoid the risk of electric shock.
    • Unscrew the coin screw for the hard drive using a coin. Pry off the HDD cover.
    • It is easier to remove the coin screw using a thicker coin, such as a nickel.
    FixBot'a Sor
  5. IBM ThinkPad 600E Display Replacement: adım 5, 3 resimden 1. IBM ThinkPad 600E Display Replacement: adım 5, 3 resimden 2. IBM ThinkPad 600E Display Replacement: adım 5, 3 resimden 3.
    • Unlock the highlighted latch and pull the disk drive out.
    • Remove the disk drive.
    FixBot'a Sor
  6. IBM ThinkPad 600E Display Replacement: adım 6, 3 resimden 1. IBM ThinkPad 600E Display Replacement: adım 6, 3 resimden 2. IBM ThinkPad 600E Display Replacement: adım 6, 3 resimden 3.
    • Most of the screws have a small, plastic covering attached with an adhesive. Use the metal spudger to pry it off. Make sure to note which screw came from which hole.
    • Four 18mm long M2.5 screws
    • Two 16mm long M2.5 screws
    • One 4.5mm long M2.5 screws
    • Four 3mm long M2.5 screws
    FixBot'a Sor
  7. IBM ThinkPad 600E Display Replacement: adım 7, 2 resimden 1. IBM ThinkPad 600E Display Replacement: adım 7, 2 resimden 2.
    • Open the laptop all the way until it is flat.
    • Take the black circle off and remove the screw.
    FixBot'a Sor
  8. IBM ThinkPad 600E Display Replacement: adım 8, 3 resimden 1. IBM ThinkPad 600E Display Replacement: adım 8, 3 resimden 2. IBM ThinkPad 600E Display Replacement: adım 8, 3 resimden 3.
    • Pry the keyboard case up from the bottom and gently pry it up from all other edges.
    • Use caution when opening the case, as there are two ribbon cables attached to the keyboard case.
    FixBot'a Sor
  9. IBM ThinkPad 600E Display Replacement: adım 9, 3 resimden 1. IBM ThinkPad 600E Display Replacement: adım 9, 3 resimden 2. IBM ThinkPad 600E Display Replacement: adım 9, 3 resimden 3.
    • Pry the connectors of the ribbon cables off slowly, lifting straight up. Wiggle gently side to side if necessary.
    FixBot'a Sor
  10. IBM ThinkPad 600E Display Replacement, Display: adım 10, 2 resimden 1. IBM ThinkPad 600E Display Replacement, Display: adım 10, 2 resimden 2.
    • Remove the plastic part attached to the bottom of the screen.
    • Gently pull it from one side and then from another.
    FixBot'a Sor
  11. IBM ThinkPad 600E Display Replacement: adım 11, 1 resimden 1.
    • Remove the highlighted screws.
    • Five 4.8mm long M2.5 screws
    FixBot'a Sor
  12. IBM ThinkPad 600E Display Replacement: adım 12, 3 resimden 1. IBM ThinkPad 600E Display Replacement: adım 12, 3 resimden 2. IBM ThinkPad 600E Display Replacement: adım 12, 3 resimden 3.
    FixBot'a Sor
  13. IBM ThinkPad 600E Display Replacement: adım 13, 1 resimden 1.
    • Close the laptop and turn it around. There you will see 4 more screws.
    • Unscrew highlighted screws.
    • Four 4.8mm long M2.5 screws
    FixBot'a Sor
  14. IBM ThinkPad 600E Display Replacement: adım 14, 2 resimden 1. IBM ThinkPad 600E Display Replacement: adım 14, 2 resimden 2.
    • After you've removed the screws, open the laptop and gently pull the display out.
    • Be sure you hold it from the bottom edges while taking it out.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin Nguyen
737 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Nance Fall 2016 USF Tampa, Team 1-4, Nance Fall 2016 üyesi
USFT-NANCE-F16S1G4
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 73
Her zaman: 2,095
