Ana içeriğe geç
IBM ThinkPad A30 Fan Replacement
Neye ihtiyacın var
  1. IBM ThinkPad A30 Fan Replacement, Battery: adım 1, 2 resimden 1. IBM ThinkPad A30 Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. IBM ThinkPad A30 Fan Replacement, Upper Case: adım 2, 1 resimden 1.
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
  3. IBM ThinkPad A30 Fan Replacement: adım 3, 1 resimden 1.
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
  4. IBM ThinkPad A30 Fan Replacement: adım 4, 2 resimden 1. IBM ThinkPad A30 Fan Replacement: adım 4, 2 resimden 2.
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
  5. IBM ThinkPad A30 Fan Replacement: adım 5, 3 resimden 1. IBM ThinkPad A30 Fan Replacement: adım 5, 3 resimden 2. IBM ThinkPad A30 Fan Replacement: adım 5, 3 resimden 3.
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
  6. IBM ThinkPad A30 Fan Replacement: adım 6, 3 resimden 1. IBM ThinkPad A30 Fan Replacement: adım 6, 3 resimden 2. IBM ThinkPad A30 Fan Replacement: adım 6, 3 resimden 3.
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
  7. IBM ThinkPad A30 Fan Replacement: adım 7, 2 resimden 1. IBM ThinkPad A30 Fan Replacement: adım 7, 2 resimden 2.
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
  8. IBM ThinkPad A30 Fan Replacement: adım 8, 3 resimden 1. IBM ThinkPad A30 Fan Replacement: adım 8, 3 resimden 2. IBM ThinkPad A30 Fan Replacement: adım 8, 3 resimden 3.
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
  9. IBM ThinkPad A30 Fan Replacement, Display Assembly: adım 9, 1 resimden 1.
    • Remove the 5.6mm screw that holds the LCD to the upper case.
  10. IBM ThinkPad A30 Fan Replacement: adım 10, 3 resimden 1. IBM ThinkPad A30 Fan Replacement: adım 10, 3 resimden 2. IBM ThinkPad A30 Fan Replacement: adım 10, 3 resimden 3.
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
  11. IBM ThinkPad A30 Fan Replacement: adım 11, 2 resimden 1. IBM ThinkPad A30 Fan Replacement: adım 11, 2 resimden 2.
    • Pull out the white tab connecting the LCD to the motherboard.
  12. IBM ThinkPad A30 Fan Replacement: adım 12, 2 resimden 1. IBM ThinkPad A30 Fan Replacement: adım 12, 2 resimden 2.
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
  13. IBM ThinkPad A30 Fan Replacement: adım 13, 3 resimden 1. IBM ThinkPad A30 Fan Replacement: adım 13, 3 resimden 2. IBM ThinkPad A30 Fan Replacement: adım 13, 3 resimden 3.
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
  14. IBM ThinkPad A30 Fan Replacement, Fan: adım 14, 1 resimden 1.
    • Remove the following screws from the fan retention bracket:
    • Single 5.6 mm screw.
    • Three 16.1 mm screws.
  15. IBM ThinkPad A30 Fan Replacement: adım 15, 1 resimden 1.
    • Lift the heatsink bracket up.
  16. IBM ThinkPad A30 Fan Replacement: adım 16, 3 resimden 1. IBM ThinkPad A30 Fan Replacement: adım 16, 3 resimden 2. IBM ThinkPad A30 Fan Replacement: adım 16, 3 resimden 3.
    • Be careful not to pull too hard. There is a cable attached to the fan.
    • Lift the fan/heatsink assembly up.
    • Locate the fan power cable and pull upwards near the connector.
    • Remove the fan/heatsink assembly.
Sonuç
Jessica
162 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G44
4 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 2,770
