Ana içeriğe geç
IBM ThinkPad A31 CPU Replacement
Neye ihtiyacın var
  1. IBM ThinkPad A31 CPU Replacement, Hard Drive: adım 1, 3 resimden 1. IBM ThinkPad A31 CPU Replacement, Hard Drive: adım 1, 3 resimden 2. IBM ThinkPad A31 CPU Replacement, Hard Drive: adım 1, 3 resimden 3.
    • Remove the 6mm screw
    • Pull out the hard drive
    • The hard drive might be a little tough to pull out
  2. IBM ThinkPad A31 CPU Replacement, Keyboard: adım 2, 3 resimden 1. IBM ThinkPad A31 CPU Replacement, Keyboard: adım 2, 3 resimden 2. IBM ThinkPad A31 CPU Replacement, Keyboard: adım 2, 3 resimden 3.
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  3. IBM ThinkPad A31 CPU Replacement: adım 3, 2 resimden 1. IBM ThinkPad A31 CPU Replacement: adım 3, 2 resimden 2.
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  4. IBM ThinkPad A31 CPU Replacement: adım 4, 3 resimden 1. IBM ThinkPad A31 CPU Replacement: adım 4, 3 resimden 2. IBM ThinkPad A31 CPU Replacement: adım 4, 3 resimden 3.
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
  5. IBM ThinkPad A31 CPU Replacement, Display: adım 5, 2 resimden 1. IBM ThinkPad A31 CPU Replacement, Display: adım 5, 2 resimden 2.
    • Remove the one 21mm screw
  6. IBM ThinkPad A31 CPU Replacement: adım 6, 2 resimden 1. IBM ThinkPad A31 CPU Replacement: adım 6, 2 resimden 2.
    • Take the tool and run it under the black case.
  7. IBM ThinkPad A31 CPU Replacement: adım 7, 3 resimden 1. IBM ThinkPad A31 CPU Replacement: adım 7, 3 resimden 2. IBM ThinkPad A31 CPU Replacement: adım 7, 3 resimden 3.
    • Unscrew the 2 (17mm) screws
    • Unscrew the 6mm screw
  8. IBM ThinkPad A31 CPU Replacement: adım 8, 2 resimden 1. IBM ThinkPad A31 CPU Replacement: adım 8, 2 resimden 2.
    • Gently disconnect the white display ribbon cable
    • Pulling on the ribbon cable too hard could result in worse or faulty connection.
  9. IBM ThinkPad A31 CPU Replacement: adım 9, 3 resimden 1. IBM ThinkPad A31 CPU Replacement: adım 9, 3 resimden 2. IBM ThinkPad A31 CPU Replacement: adım 9, 3 resimden 3.
    • Unscrew 4 (6mm) screws
    • Lift screen straight up
    • If not lifted straight up the screen could get damaged
  10. IBM ThinkPad A31 CPU Replacement, Battery: adım 10, 2 resimden 1. IBM ThinkPad A31 CPU Replacement, Battery: adım 10, 2 resimden 2.
    • Flip the ThinkPad over so that it is upside down.
    • Push latch switch to the left.
    • Gently lift the battery out and away from the ThinkPad
    • You have to hold the latch to the left while you remove the battery. Simply pushing once will not unlock the battery
  11. IBM ThinkPad A31 CPU Replacement, CPU: adım 11, 3 resimden 1. IBM ThinkPad A31 CPU Replacement, CPU: adım 11, 3 resimden 2. IBM ThinkPad A31 CPU Replacement, CPU: adım 11, 3 resimden 3.
    • LIft the bracket out
  12. IBM ThinkPad A31 CPU Replacement: adım 12, 3 resimden 1. IBM ThinkPad A31 CPU Replacement: adım 12, 3 resimden 2. IBM ThinkPad A31 CPU Replacement: adım 12, 3 resimden 3.
    • Remove one 6mm screw
    • Remove 3 18mm screws
    • Take off the bracket on the CPU fan
  13. IBM ThinkPad A31 CPU Replacement: adım 13, 3 resimden 1. IBM ThinkPad A31 CPU Replacement: adım 13, 3 resimden 2. IBM ThinkPad A31 CPU Replacement: adım 13, 3 resimden 3.
    • Lift the CPU fan
    • Pull out the cable attached to the motherboard
  14. IBM ThinkPad A31 CPU Replacement: adım 14, 2 resimden 1. IBM ThinkPad A31 CPU Replacement: adım 14, 2 resimden 2.
    • Turn the locking screw to unlock with the flat head screwdriver
    • LIft the CPU out
Sonuç
Bir başkası bu kılavuzu tamamladı.
Thomas Stone
235 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G2, Bernier Spring 2018 UMass Dartmouth, Team S2-G2, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S2G2
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 899
