Ana içeriğe geç
IBM ThinkPad A31 Display Replacement
Neye ihtiyacın var
  1. IBM ThinkPad A31 Display Replacement, Keyboard: adım 1, 3 resimden 1. IBM ThinkPad A31 Display Replacement, Keyboard: adım 1, 3 resimden 2. IBM ThinkPad A31 Display Replacement, Keyboard: adım 1, 3 resimden 3.
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  2. IBM ThinkPad A31 Display Replacement: adım 2, 2 resimden 1. IBM ThinkPad A31 Display Replacement: adım 2, 2 resimden 2.
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  3. IBM ThinkPad A31 Display Replacement: adım 3, 3 resimden 1. IBM ThinkPad A31 Display Replacement: adım 3, 3 resimden 2. IBM ThinkPad A31 Display Replacement: adım 3, 3 resimden 3.
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
  4. IBM ThinkPad A31 Display Replacement, Display: adım 4, 2 resimden 1. IBM ThinkPad A31 Display Replacement, Display: adım 4, 2 resimden 2.
    • Remove the one 21mm screw
    • Remove the 6mm screw
  5. IBM ThinkPad A31 Display Replacement: adım 5, 2 resimden 1. IBM ThinkPad A31 Display Replacement: adım 5, 2 resimden 2.
    • Take the tool and run it under the black case.
  6. IBM ThinkPad A31 Display Replacement: adım 6, 3 resimden 1. IBM ThinkPad A31 Display Replacement: adım 6, 3 resimden 2. IBM ThinkPad A31 Display Replacement: adım 6, 3 resimden 3.
    • Unscrew the 2 (17mm) screws
    • Unscrew the 6mm screw
  7. IBM ThinkPad A31 Display Replacement: adım 7, 2 resimden 1. IBM ThinkPad A31 Display Replacement: adım 7, 2 resimden 2.
    • Gently disconnect the white display ribbon cable
    • Pulling on the ribbon cable too hard could result in worse or faulty connection.
  8. IBM ThinkPad A31 Display Replacement: adım 8, 3 resimden 1. IBM ThinkPad A31 Display Replacement: adım 8, 3 resimden 2. IBM ThinkPad A31 Display Replacement: adım 8, 3 resimden 3.
    • Unscrew 4 (6mm) screws
    • Lift screen straight up
    • If not lifted straight up the screen could get damaged
Sonuç
Sean Tocci
293 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G2, Bernier Spring 2018 UMass Dartmouth, Team S2-G2, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S2G2
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
i have that but display is
not work
Ahmed Elwy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 479
