Ana içeriğe geç
IBM ThinkPad A31 Keyboard Replacement
Neye ihtiyacın var
  1. IBM ThinkPad A31 Keyboard Replacement, Battery: adım 1, 2 resimden 1. IBM ThinkPad A31 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the ThinkPad over so that it is upside down.
    • Push latch switch to the left.
    • Gently lift the battery out and away from the ThinkPad
    • You have to hold the latch to the left while you remove the battery. Simply pushing once will not unlock the battery
  2. IBM ThinkPad A31 Keyboard Replacement, Keyboard: adım 2, 3 resimden 1. IBM ThinkPad A31 Keyboard Replacement, Keyboard: adım 2, 3 resimden 2. IBM ThinkPad A31 Keyboard Replacement, Keyboard: adım 2, 3 resimden 3.
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  3. IBM ThinkPad A31 Keyboard Replacement: adım 3, 2 resimden 1. IBM ThinkPad A31 Keyboard Replacement: adım 3, 2 resimden 2.
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  4. IBM ThinkPad A31 Keyboard Replacement: adım 4, 3 resimden 1. IBM ThinkPad A31 Keyboard Replacement: adım 4, 3 resimden 2. IBM ThinkPad A31 Keyboard Replacement: adım 4, 3 resimden 3.
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matheus
128 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G2, Bernier Spring 2018 UMass Dartmouth, Team S2-G2, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S2G2
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 403
