Ana içeriğe geç
IBM ThinkPad R40 Hard Drive Replacement
Neye ihtiyacın var
  1. IBM ThinkPad R40 Hard Drive Replacement, Remove the battery: adım 1, 2 resimden 1. IBM ThinkPad R40 Hard Drive Replacement, Remove the battery: adım 1, 2 resimden 2.
    • To remove the battery, slide the battery lock lever right, while pulling on the battery tab.
  2. IBM ThinkPad R40 Hard Drive Replacement, Remove the hard drive holder.: adım 2, 2 resimden 1. IBM ThinkPad R40 Hard Drive Replacement, Remove the hard drive holder.: adım 2, 2 resimden 2.
    • Remove the Phillips #1 screw from the bottom of the laptop.
    • Pull on the small rise in the plastic to remove the hard drive holder.
    • Don't be afraid to use some force, it requires quite a bit of pressure to remove.
  3. IBM ThinkPad R40 Hard Drive Replacement, Remove the hard drive holder.: adım 3, 3 resimden 1. IBM ThinkPad R40 Hard Drive Replacement, Remove the hard drive holder.: adım 3, 3 resimden 2. IBM ThinkPad R40 Hard Drive Replacement, Remove the hard drive holder.: adım 3, 3 resimden 3.
    • Remove the hard drive holder completely from the computer.
    • Push on the plastic, and the hard drive will pop out.
  4. IBM ThinkPad R40 Hard Drive Replacement, Remove the hard drive.: adım 4, 1 resimden 1.
    • Remove the four Phillips #1 screws.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alec M
82 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 5,214
