Ana içeriğe geç
IBM ThinkPad R40 Keyboard Keys Replacement
Neye ihtiyacın var
  1. IBM ThinkPad R40 Keyboard Keys Replacement, Disconnection: adım 1, 1 resimden 1.
    • Make sure your laptop is off and disconnected from the power source to ensure safety for yourself.
    FixBot'a Sor
    Yorum Ekle
  2. IBM ThinkPad R40 Keyboard Keys Replacement, Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Locate the key that needs replacing. Use tweezers to slowly pull the key off the keyboard. Doing this will expose the underside of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  3. IBM ThinkPad R40 Keyboard Keys Replacement, Set aside: adım 3, 1 resimden 1.
    • Step 3: Set the old key aside and have the new key ready to be inserted onto the computer. The key has three parts, which you can see here.
    FixBot'a Sor
    Yorum Ekle
  4. IBM ThinkPad R40 Keyboard Keys Replacement, Moving inside: adım 4, 1 resimden 1.
    • The new key will have an empty slot where they key used to be. It contains a small rubber spring. After the rubber spring is inserted take the new key and line it up according to the color springs on the backside of the key along with the keyboard.
    FixBot'a Sor
    Yorum Ekle
  5. IBM ThinkPad R40 Keyboard Keys Replacement, Lining up: adım 5, 1 resimden 1.
    • After lining the key up, the black and white pieces will line up.
    FixBot'a Sor
    Yorum Ekle
  6. IBM ThinkPad R40 Keyboard Keys Replacement, Finishing up: adım 6, 1 resimden 1.
    • Step 6: The key should not be firmly locked into place and functioning normally.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Erin
231 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 52
Her zaman: 5,289
