Ana içeriğe geç
IBM ThinkPad T30 Hard Drive Replacement
Neye ihtiyacın var
  1. IBM ThinkPad T30 Hard Drive Replacement, Battery: adım 1, 3 resimden 1. IBM ThinkPad T30 Hard Drive Replacement, Battery: adım 1, 3 resimden 2. IBM ThinkPad T30 Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
    FixBot'a Sor
    Yorum Ekle
  2. IBM ThinkPad T30 Hard Drive Replacement, Hard Drive: adım 2, 1 resimden 1.
    • Flip to the back of the Thinkpad.
    • Remove the single 11 mm screw using the Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. IBM ThinkPad T30 Hard Drive Replacement: adım 3, 3 resimden 1. IBM ThinkPad T30 Hard Drive Replacement: adım 3, 3 resimden 2. IBM ThinkPad T30 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Flip the Thinkpad on its side to get a better view of the hard drive.
    • Push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad.
    • Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
    FixBot'a Sor
    Yorum Ekle
  4. IBM ThinkPad T30 Hard Drive Replacement: adım 4, 2 resimden 1. IBM ThinkPad T30 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Using the plastic tool, remove the black plastic cover from the main body of the hard drive.
    • Place the plastic tool at the ends of the plastic cover to detach it from the hard drive.
    • Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
    FixBot'a Sor
    Yorum Ekle
  5. IBM ThinkPad T30 Hard Drive Replacement: adım 5, 2 resimden 1. IBM ThinkPad T30 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Remove the four 2.8 mm screws from the mounting bracket using a Phillips #0 screwdriver.
    • Pull the mounting bracket off of the hard drive.
    • It may be easier to remove the mounting bracket by rotating it off of the hard drive as if it is on a hinge.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
11 farklı kişi bu kılavuzu tamamladı.
Allie Knauer
90 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-20, Amido Fall 2012 Cal Poly, Team 3-20, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S3G20
3 Üyeler
17 adet Kılavuz yazıldı
1Rehber Yorum
good description and photos..thanks :]
David - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 18
Son 30 gün: 99
Her zaman: 20,729
