Ana içeriğe geç
IBM ThinkPad T30 Keyboard Replacement
Neye ihtiyacın var
    1. IBM ThinkPad T30 Keyboard Replacement, Battery: adım 1, 3 resimden 1. IBM ThinkPad T30 Keyboard Replacement, Battery: adım 1, 3 resimden 2. IBM ThinkPad T30 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
      • Make sure the ThinkPad is off and the power supply is unplugged.
      • Flip the ThinkPad upside down with the bottom facing you.
      • Slide the latch to the right into the unlock position.
      • While holding the latch in the unlock position, lift the battery out with your other hand.
      FixBot'a Sor
      Yorum Ekle
    1. IBM ThinkPad T30 Keyboard Replacement, Keyboard: adım 2, 2 resimden 1. IBM ThinkPad T30 Keyboard Replacement, Keyboard: adım 2, 2 resimden 2.
      • Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw. One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover.
      • Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
      • Be sure to not lift the keyboard too far. It is still attached to the computer with a ribbon connector.
      FixBot'a Sor
      Yorum Ekle
    2. IBM ThinkPad T30 Keyboard Replacement: adım 3, 3 resimden 1. IBM ThinkPad T30 Keyboard Replacement: adım 3, 3 resimden 2. IBM ThinkPad T30 Keyboard Replacement: adım 3, 3 resimden 3.
      • Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact.
      • If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced
      • Use the plastic opening tool to gently pry the connector up from the motherboard.
      • You can now safely remove the keyboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alex Kost
271 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-20, Amido Fall 2012 Cal Poly, Team 3-20, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S3G20
3 Üyeler
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 44
Her zaman: 3,730
